Ordered QA1 front shock and spring..rear?
I just ordered a set of qa1 12 way adjustable front shock's and front springs. I am currently running competition eng. rear shocks. I am running a custom set of springs that I had made, that were heated and shrunk 1" Should I keep these springs, or should I place a stock set of springs in the rear. The car will be a street/strip vehicle. Thanks
Re: Ordered QA1 front shock and spring..rear?
Well, I am running that same setup in my 1994 Trans Am. Hal 12 ways up front with their drag springs up front, and Comp. Eng. 3 way adjustable drag rear shocks with stock LT1 coil springs with the rubber isolater removed. It lowers the rear about 1/2 to 3/4 of an inch. It aint the absolute most smoothest ride, but it is not horrible by any means. It feels exactly like what it is, a drag setup.
texasTA, did you re-use the stock top spring seat and "dog biscuit"?
If not what did you need?
I am using the 300lb Hal spring. Do you have any tips for install?
Originally Posted by OBE1 95Z28
Anyone using Hal springs!! Please.
You can get rid of the spring insulator and use a piece of 5/8 heater hose cut down the middle, spread apart and wrapped around the top coil. It will take care of SOME of the harshness.
Kyle
Kyle
Kyle
Kyle
