panhard bar bolt problem
i got a new tubular pandhard bar from paracing.com and i wa changing it along with my lcas a few days ago
and believe it or not, the bolts were not hard to get off on my 18 year old f-body
anyway, the bolt from the original panhard bar starts off as a 12 mm bolt but then widens to i guess 14 mm and it fits fine in the bushing sleeve of the stock pandhard bar, but only goes halway in the new bushing sleeve in the new panhard bar, i need a replacement set of bolts that have a constant diameter
i went everywhere (autozone, pep boys, home depot, hardware store and sears hardware) and no body has a strong enough bolt
the original bolt has 10.9 stamped in the head and is an m12 x 1.75 pitch bout 4 inches long
all the above places have 8.8 not 10.9 and i dont want to use that
Re: panhard bar bolt problem
If you have a Lowe's near you try them. The Lowe's in my area has Grade 10.9 metric hardware. If you can't find 10.9 metric just use 1/2 Grade 8 SAE. Any good hardware store should have Grade 8 bolts.
![Exclamation](https://www.camaroz28.com/forums/images/icons/icon4.gif)
Don't be confused by the 8.8 grade. If I remember correctly, 8.8 is not equal or stronger than grade 8. I am looking this up but in the meantime, to anyone looking for grade 8, do not use 8.8 in its place. Like LPEdave said, 10.9 is the same as grade 8.
I thought this might be important as people have a tendency to think 8.8 is stronger than 8.
yea thats good to know, i know alot of poeple dont understand bolts, sizes pitches and strengths, i've already learned a bit about bolts which is why i didnt go for 8.8 bolts
i'll try ace hardware for the 10.9 bolts in m12 1.75 pitch
i know i could use grade 8 bolts but i'm not to sure what size to get to make sure they fit inside my panhard bar, too lazy to measure and all that good stuff
thanks alot guys, i'll let u know if i find them
Originally Posted by LPEdave
Try an ACE hardware, if you have them. In my neck of the woods they carry 10.9 class metric hardware (which is comparable to grade 8 SAE).
Dave
Dave
![Thumbs up!](https://www.camaroz28.com/forums/images/smilies/thumb.gif)
![Wink](https://www.camaroz28.com/forums/images/smilies/wink.gif)
i felt the car needed a panhard rod more than i needed to take the bolt with me so i simply memorized the dimesions of the bolt, like i said before, m12 x 1.75 pitch, 10.9 quality and its around 4 inches in length
i cant find an ace hardware around me, i called the guy from pa racaing where i got my stuff and he offers bolt kits for the lca's and panhard bar for 10 bucks,
i think i'm going to either buy the bolt kits through pa racing, or buy grade 8 bolts if i cant find an ace hardware
slothgrant
08-22-2002 03:01 PM
SavageZ28
17
07-14-2002 11:04 PM
