which panhard rod?
Old 08-02-2008, 12:39 PM
TrocN98's Avatar
which panhard rod?
i have a 98 v6 camaro. i have 18 inch vette wheels on the rear. i have a stock panhard rod, and i can tell its bent (car was in an accident a long time ago) and i need to re center the rear end.
i want the umi performance one.
do i need a double adjustable one? do i need it to be chrom moly or whatever?
what does chrom moly mean anyways? thanks.
TrocN98 is offline
Old 08-02-2008, 01:35 PM
bluz28's Avatar
Thumbs up
No you don't need a chrome-moly, or the double adjustable one.
Just get a single adjustable one.
Chrome-moly is stronger/harder, so it doesn't have to be a thick to have the same strength as lesser metals It's also cost more!
Also known as 4130, this steel is often called chrome-moly because of the chromium and molybdenum concentration .
bluz28 is offline
Old 08-02-2008, 02:47 PM
TrocN98's Avatar
so what would be the purpose of buying a double adjustable over a single adjustable?
TrocN98 is offline
Old 08-02-2008, 08:07 PM
bluz28's Avatar
Lightbulb
Beside moving up/down it also pivots a little left/right. The purpose of the heim joints being adjustable is that their also replaceable so when they wear-out you just have to replace the Heim Joints, not the bar itself!
bluz28 is offline
Old 08-02-2008, 09:55 PM
TrocN98's Avatar
so if i need to recenter the rear i only need a single adjustable?
but if i only want to replace bushings in the long run, i should get the double adjustable right?
and as for chrom-moly, is that just a weight reduction feature?
TrocN98 is offline
Old 08-02-2008, 11:36 PM
bluz28's Avatar
Thumbs up
Yes
IMO, double adjustable is over kill. The "On Car" single adjustable is what I have now and prefer over the poly/poly non-adjustable , and the double (heim joint)adjustable.
Yeah, strength/ weight reduction.
bluz28 is offline
Old 08-03-2008, 04:08 PM
The difference between "single" adjustable panhard rod and "double" adjustable has to do with how you adjust it, not now many adjustments there are. The single adjustable only has a single threaded "end", so you have to remove the end of the bar from the bolt, screw it in or out what you assume is the correct number of turns, then reinstall it to see if you got it right. Double adjustable has two "ends" with opposite hand threads, that allow you to adjust the length of the bar without removing it from the bolts.
Double adjustable is a lot easier to "adjust".... but its simply a matter of convenience. And single or double adjustable has nothing to do with whether it uses a spherical rod end (Heim) or simply poly bushings. You can buy either type in single or double adjustable.
Injuneer is offline
Old 08-03-2008, 05:59 PM
4U 2 NV's Avatar
absolutely...the double adjustable are usually done so with an adjustable "nut" in the middle of the bar...not at the end like the single adjsutable.
4U 2 NV is offline
Old 08-03-2008, 10:16 PM
slomarao's Avatar
If you want someone to tell you everything you could want to know about one i would call Sam strano. www.stranoparts.com He will set you stright.
slomarao is offline
Old 08-03-2008, 11:24 PM
bluz28's Avatar
Lightbulb
Sorry Injuneer, I'll have to disagree with you . The "On Car" single adjustable is the easiest , IMO to adjust on the car, all the adjustments are done on one end of the panhard bar.
This is what it looks like:
http://www.umiperformance.com/2022?category_id=124
bluz28 is offline
Old 08-04-2008, 06:01 PM
And that is "double" adjustable, because it has a PAIR of threads that allow on-car adjustment. A "single" adjustable only has one "thread" and must be removed from the bolt to be turned/adjusted. Doesn't matter whether you put the two threaded sections on the "ends" or on the center adjuster - its still double adjustable. There are no "up and down" adjustments in any case. Only the length is "adjustable".
Mine has the opposite threads, and the adjustment is made with a nut on one end of the bar.
Injuneer is offline
Old 08-04-2008, 10:44 PM
bluz28's Avatar
Thumbs up
OK, you got me there!....My bad!So I guess then it's my single sided double adjustable poly/ heim joint panhard bar(with no up/down adjustment) that's easier to adjust !...
Thanks for the correction,very good point.
bluz28 is offline
Old 08-05-2008, 07:21 AM
Green96Z's Avatar
Ok, now I'm confused. I had always thought this one was single adjustable:
http://www.bmrfabrication.com/phr/PHR002_large.jpg
while this one was double adjustable:
http://www.bmrfabrication.com/phr/MPHR003_large.jpg
I have the first one, and can adjust it on the car without pulling out the mounting bolts.
Green96Z is offline
Old 08-05-2008, 08:17 AM
Shon Herron's Avatar
Which ever one you want, contact me for great pricing and free shipping!
Shon Herron is offline
Old 08-06-2008, 05:25 PM
BOTH of them can be adjusted with the bar fully installed. I have the second one. The bottom/second one has threads on BOTH rod ends. One is right-hand threaded, and the other is left-hand threaded. You loosen the locknuts on both ends, and use the nut welded to the lower left end (in the picture) of the bar to rotate the bar, making the assembly longer or shorter. ....WITH the ends still on the bolts.
Injuneer is offline
Quick Reply: which panhard rod?
