Part # for Brake Booster Vacuum hose
Anyone have a part number for an LT1 brake boost vacuum hose (intake to booster)? The dealer could not find one. If they are not available, what are others doing?
I have an LT1 in my 69 camaro and was hoping to use this same line.
thanks,
Kevin
thanks,
Kevin
10257250 still shows available at http://www.newgmparts.com .
shoebox, what the dealer pulled up isn't what I expected. They showed a hose from the booster to a vacuum port that was installed vertical into the intake manifold. the diagram had 2002 model year on it. Is the part number you gave for a LS engine? I'm looking for an LT engine. I haven't seen the hose. I assume it goes from the boost, around the back of the engine, under the injector covers and makes a 90 degree turn attaching to the vacuum fitting into the side of the LT intake.
Any help is appreciated.
Thanks,
Kevin
Thanks,
Kevin
