Part Number for upper control arm support?
My parts manual is in another town -- wasn't sure if anyone would go through the hassle of looking this up for me.
Doing shocks/springs, finishing the last corner (front passenger side), and was poking rust off with a screwdriver... which went entirely through the steel. So much corrosion, it looks like that thing was pulled up from the ocean floor.
I'm a decent welder, but I'm not sure if I should attempt to fix that -- it has a contour to it, and I wouldn't want to cause any alignment problems?
![](http://www.lt1info.com/temp/crap.jpg)
![](http://www.lt1info.com/temp/crap2.jpg)
Eh, crap. Dug around some more with the search, and found someone says it comes as part of the entire assembly.
Soooo. Looks like I might just try to cut out the affected area and weld some fresh steel in there. Any foreseeable problems with doing so?
Brandon Wittmer
12-07-2014 12:15 PM
