pedal stops after an inch or so
Brakes were a bit weak, but the real problem is the pedal hitting a hard stop after an inch of travel. I replaced all the calipers as they were worn, and even the booster. The master is not very old, and I even swapped the abs unit to see if it made a difference, which it did not. Anyone come across a problem like this and find a solution? I plan on going through it again and attempt to isolate the problem, but I always like to take advice when starting out.
05-21-2015 01:04 PM
CGM2010CAMARO
04-07-2015 07:44 PM
