performance rotors for ls1
I was thinking on swopping my factory rotors for some cross drilled or slotted ones. What i had in mind is putting some brembo cross drilled rotors. what do you guys think? if you have suggestions on rotors that are better or where i can get them for a cheap price let me know. thanks guys
Re: performance rotors for ls1
Originally Posted by slp223
i got bear earidspeeds two peice if they warp or wear our you can replace the the friction part with out having to get new hats
Your not gonig to see increased braking from slottd or cross drilled rotors. As you are actually decreasing the swept area your braking should actually go down. The benifit comes under repeated hard braking when the brakes get real hot. The slotted or crossdrilled rotors will cool faster and provide increased braking in that instance.
Personally I would stay away from all but the highest quality drilled rotors. Almost every one I've ever seen eventually gets cracks around the holes. I use Power Slot rotors and they look great and didn't cost too much.
10-31-2016 11:09 AM
bossco
11-29-2014 10:18 AM
07-04-2005 05:00 PM
