Pictures of my LS1 brake upgrade
#16
Re: Pictures of my LS1 brake upgrade
Originally Posted by LT4ever
The brake lines that came with the set up had a hard metal line that came out of the banjo bolt where it meets the caliper and then turns into a rubber hose. It has about 2" of metal line from the caliper. I'm wondering if this is a brake line out of a car with traction control or are all the LS1 stock flex lines like that?
#17
Yeah... good idea. The passenger side brake line that comes from the banjo bolt and turns from metal to rubber is about a half inch or less from the tire rim. I bent the hard line to position the flex hose away from the tire. But the flex line makes a pretty tight curve radius to get it away from the rim.
I hadn't thought about moving the banjo fitting to postion it better. (Gawd... I hate bleeding the brakes!!)
F'n1996Z28SS
08-23-2023 11:19 PM
10-31-2016 11:09 AM
