Pinion Angle
Pinion Angle
I just got the BMR track pack and it says to adjust the pinion angle for a manual tranny to -2 to -3 degrees. How does this affect traction. I don't understand how the angle of the rear end is affected by that. Thanks for any help.
BMR's method is a little misleading. Make sure to measure the angles from the driver's side.
http://www.go-fast.org/z28/pinionangle.html
I've been doing some research on BMR's site and here is what I found. Thought this might help others with my same question.
Why is the correct pinion angle important?
When a car launches, the rear suspension twists and the pinion angle moves upward. With a stock suspension, there is no way to adjust for this and the pinion angle will enter a positive angle(pointing upward). Ideally you want to adjust the pinion angle down(negative) when the car is unloaded. Then on vehicle launch that angle should never exceed zero degrees if set properly. If the angle exceeds zero and becomes positive, there are chances of driveline bind and maximum torque is not applied.
Depends also on how much power the engine is putting out.... the more power, the larger the required negative angle. And, it also depends on what the front of the torque arm looks like.... a rubber mount deflects the most, poly next, and the spherical rod end deflects the least. I've seen numbers recommended as high as -4deg for high power (500+HP) cars running a poly front bushing. And, you can't "street" drive with that much negative pinion angle, you have to readjust to -2deg or less when you leave the track.
I think most setups will be OK with -2deg.
08-07-2015 01:26 PM
kev93z28
08-19-2002 12:48 AM
