Please help with pinion angle equation....
I have an adj. bmr torque arm on my '94Z A4. After install and making some adjustments I placed the angle finder on the bottom of the TA mounting plate and got a reading of -5*. Then I rotated my driveshaft so that I could place the angle finder on the flattest part of the yoke which read -3.5*. Both measurements were taken facing the driver side. Both the driveshaft and pinion are slightly facing downward forming the "V" angle. Would the correct equation be: (-5*) - (-3.5*)= -1.5*?? My goal was to get between -1* and -2*.
Follow every step of this link and it should be perfect.
http://www.streetissuecustoms.com/pinionangle.html
08-07-2015 01:26 PM
kev93z28
08-19-2002 12:48 AM
