Popping noise when i brake sometimes???
Re: Popping noise when i brake sometimes???
Its your Brake pad moving back and forth inside the Caliper. as you move on reverse... the pad will slide in one direction ... then you drive forward and when you apply enough pressure it will slide in the other direction till the calliper stops it... and you hear that little pop.
I fix mine with some of that grease (for lack of better words) that they sell to eliminate brake noise at the auto parts... when it dries it glues the pad to the other metal parts... or at least keeps it from moving
When the pads were manufactured.. they were made about a millimiter too small... so they have a little play.
If that is not your problem then I have no idea what is...
Marvin
Marvin
carguyshu
01-22-2017 11:19 AM
Gtpguy
01-26-2015 04:50 PM
