possible suspension problem???
![Exclamation](https://www.camaroz28.com/forums/images/icons/icon4.gif)
It seems like my rear-end has moved. The driver-side tire sticks out farther than my passenger-side tire. The offset and Backspacing is the same for all four of my tires. On my passenger-side tire, the top seems to be angled in a bit. Any ideas on what could be wrong??
not sure. maybe check your panhard rod and see if anything is amiss including the mounting points and such.
and about the top of the tire looking like its angled, maybe you should get your alignment checked.
Re: possible suspension problem???
Originally posted by My Red 93Z-28
. . . On my passenger-side tire, the top seems to be angled in a bit. Any ideas on what could be wrong??
Make sure that your right rear wheel isn't bent and that your RR axle bearing is in good shape.
After all that, it may be a case of you having developed a little negative camber in that axle. Not a bad thing to have in small doses for performance handling (up to -1* or so), and I'd guess that having precisely 0.00* degrees rear camber would be unlikely, actually.
Norm
F'n1996Z28SS
08-23-2023 11:19 PM
