Proportioning valve without line lock
Anyone have a Proportioning valve installed with out the line lock. I purchased a wilwood proportioning valve of a member and have no installation guide. So if anyone has pictures of the proportioning valve installed showing which brake line goes where. Also if I need to tee of brake lines please show pictures of that. I have searched and only seen pics with line lock installed. So please post pics or e-mail me an installation guide...
This is the one I have
http://store.summitracing.com/partde...5&autoview=sku
No, but try a "search".... I know people have posted pictures of their ABS deletes. SJM Manufacturing sells an ABS delete kit with the proportioning valve and lines.
http://www.sjmmanufacturing.com/cam_brk_lt1.html
I found some in a search but all have line locks to go with it. I also found ws6pilots southern engineered kits but that wasn't much help. I just want a pic with the prop valve installed.
Here is a picture of the proportioning valve on my race car. It's not the stock master cylinder, but I used the stock rear brake lines. The install is pretty straightforward. You have to cut the rear brake line and flare each end. You will probably need a couple of adapters to go from the flared brake line to 1/8 NPT fittings, which is what the proportioning valve is drilled and tapped for.
There should be some kind of markings on the valve to show which hole is in and which one is out. The line from the master cylinder goes on the input side, and the line to the rear brakes goes on the out side.
kclarson
08-22-2002 04:04 PM
