Question about front strut assembly
When replacing the complete assembly, am I forgetting anything?
-Strut(with nut and washer)
-Spring
-upper strut mount
-Strut rod dust cover
-lower spring mount
thanks
-Spring
-upper strut mount
-lower spring mount
thanks
Re: Question about front strut assembly
There is an insulator (triagular looking piece in lower middle of Injueer's pic) that goes under the top nut and washer but on top of the upper shock mount. Yes, 4th gens have front shocks, not struts. ![Smilie](https://www.camaroz28.com/forums/images/smilies/smile.gif)
Oh, there is a lower mount insulator as well.
Yes, I realize its a short arm long arm(SALA) design using a coil over shock setup.
If you want to get technical though they're not "shock absorbers", as they dont absorb road shock, just control the coil springs oscillations. But for simplicity's sake I used what most people call them by. I've never taken a 4th gens front suspension apart though, and cant find a decent schematic so I thought I would ask to get an idea.
Thanks for the help
It was just what I needed.
![Wink](https://www.camaroz28.com/forums/images/smilies/wink.gif)
Thanks for the help
Thanks for the help
Thanks for the help
![Roll Eyes (Sarcastic)](https://www.camaroz28.com/forums/images/smilies/rolleyes.gif)
PS: To get technical, questions about "suspension" belong on the correct forum... not here on "LT1 Engine Tech". Moving to "Suspension......."
Originally Posted by Injuneer
Put down the person that helps you, then thank him???? ![Roll Eyes (Sarcastic)](https://www.camaroz28.com/forums/images/smilies/rolleyes.gif)
My guess is after they see the answer they realize how ignorant they are and get embarrased and have to pop off wise.
Gets kinda hard to take, when you are trying to help the ungrateful so and so.
You provide alot of good info, and myself and others thank you for it.
Z28
Originally Posted by Z28barnett
You are right, that was a very left handed reply that the guy made. I don't know why they do it.
Z28
Z28
everyone should know a shock absorber doesnt absorb shock but not everyone knows the technical differance between a strut and a shock
and everyone should know to post suspension questions in the suspension forum instead of having injuneer move them over from lt1 engine tech, this may be the gazillionth time i've seen him mention this, of course i am guilty of asking suspension questions in 3rd gen engine tech only because i usually get ignored by 4th gens (its ok guys i'm not upset)
Thanks for noticing..... I used to spend most of my time helping people with Tech questions. Seems like lately almost all the time I spend on these boards is spent moving posts that don't belong.... just moved a question about buying a V6 off the "LT1 Engine Tech" forum. Earlier it was a guy posting on LT1 Engine Tech, with a question as to how to get the rack & pinion off his 01 Z28 LT1.... yup, that's what he said.
10-31-2016 11:09 AM
Sergio
01-27-2016 04:27 PM
ChrisFrez
01-25-2015 08:06 AM
Hurin
12-13-2014 07:38 PM
Jibberish18
08-28-2002 12:46 PM
