Question about the quality of a specific Rotor brand..
Old 08-20-2004, 01:08 PM
  #16
Camaro_Maniac63's Avatar
Re: Question about the quality of a specific Rotor brand..
Originally Posted by ZeeSNuttS
I didn't get the drilled & slotted rotors for looks. I got them because
my stock rotors were warped and I wanted a better rotor that would
take the braking from living in the hills. I have no warping with these
rotors so wouldn't you say that's a performance advantage ?
David
Your increased brake performance is NOT due to slotted/drilled rotors. I recommend that you do some more reading on the subject, as suggested in previous posts. Here is a basic explanation:
http://home.columbus.rr.com/trackbir...led_rotors.htm
And this is from BAER's website:
http://www.baer.com/Support/FAQ.aspx#1
Edit: Just realized the first link I posted is the same as Shempy's second one... I guess reading it twice wouldn't hurt
Camaro_Maniac63 is offline
Old 08-20-2004, 01:17 PM
  #17
ZeeS7o7's Avatar
Originally Posted by LPEdave
I have a car with drilled rotors, and often used slotted rotors on my Camaro that I tracked all the time. I also used blank rotors on the Camaro. I've used many different pad compounds, which seemed to provide the only noticeable change in braking capacity during repeated braking. But I haven't done any scientific study, that's already been done and I have no equipment to do it.
As others are saying, and I think corresponds to your results, your slotted/drilled rotors and whatever pads you're using may certainly be better than your stock setup was. I'm only suggesting that I really doubt it's due to the slots and holes - it's the pads and rotor quality.
Dave
Well thanks for all your info Dave
Have a good & safe weekend.
David
Oh, and sorry to Matt for hi-jacking your thread
ZeeS7o7 is offline
Old 08-20-2004, 03:21 PM
  #18
Shempy's Avatar
Which is also what I just got through reiterating, but people aren't focusing. The slotted or drilled rotors may well be better than the stock rotor, but that doesn't make them optimum. I'm saying that one would be better off with a Brembo "blank" OEM replacement rotor that doesn't have the cross drills or slots. They are less prone to crack than drilled, and less prone to warp than stock. Oh, and they're a heck of a lot cheaper and will last longer. So again, if performance is the priority, step away from the drilled. If you just want to spend even more cash and get "purdied up" while getting a better rotor than stock, then go ahead, get your cross drilled.
Shempy is offline
Old 08-20-2004, 03:39 PM
  #19
ZeeS7o7's Avatar
Ok, now I'm going to send back my drilled & slotted
for some blanks.........NOT !
Well they work for me (drilled & slotted) I thank you all
for your schooling & I'm sure Matt dose to. Now Matt
go get some Drilled rotors
You all have a good one !
David
ZeeS7o7 is offline
Old 08-20-2004, 04:27 PM
  #20
Shempy's Avatar
Shempy is offline
Old 08-21-2004, 02:36 AM
  #21
Lucas Black's Avatar
any replacement rotor is better than stock rotors....
up to you to decide what you wanna look at...
Lucas Black is offline
10-31-2016 11:09 AM
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
Queens94z28
12-20-2014 09:11 PM
07-04-2005 05:00 PM
Quick Reply: Question about the quality of a specific Rotor brand..
