Question about rear springs
I want to lower my car slightly but truthfully I just want stiffer springs. I was thinking of buying 1le springs and cutting 1 coil out. OR.. I was gonna just buy rear lowering springs from bmr. would these work are they stiffer. My tires rub now on hard bumps with factory stuff. Please give me your .2
Thanks,
tim
Thanks,
tim
Re: Question about rear springs
What size tire/wheels are you running. You should not be rubbing with stock springs if you are running stock sizes (245-275). If you go to a higher rate spring, you will also need to upgrade the shocks as well (not a bad idea even with stock springs).
I have the c5 thick spoke 18's in the back and 17's in the front. 275-40-18's in the back. with longer wheel studs and 1/4 inch spacers... even w/ out spacers the fender well is very restrictive... maybe I should just do all that and get bmr's
What do you think
Tim
What do you think
Tim
Originally Posted by 93redbird
I have the c5 thick spoke 18's in the back and 17's in the front. 275-40-18's in the back...
10-31-2016 11:09 AM
oldschool
02-09-2016 09:21 PM
