question with abs removal
ok when i remove the big abs box with the lines and plugs going to it will i set a light off?
what do i do with the clips that pluged into the abs box?
any input would be appriciated
thanks
tony
thanks
tony
Re: question with abs removal
Originally Posted by Z95m6
Is there any reason you are removing the ABS system? i don't really see a reason to do so.
1 weight reasons...it is a car i will only use at the track
2 making room under the hood and cleaning under there up
3 its fugly and im an experianced driver...dont really need abs
yea i know i wont need the box...im just wondering it a light will come on ...i cant find out as my motor and kmember are sitting on my front porch! lol
also all the plug in clips that go into the abs box do i just tuck them away somewhere or what?
thanks alot
tony
thanks alot
tony
Yes, you will get a light. (why wouldn't you?) You will need to remove the abs bulb behind the dash, or have it edited out of your ECU. As for the plugs.. hide them or snip them as I stated above. Just make sure if you do, that no bare wire is present.
i have to send my ecu back out for tuning so i may have it edited out then...i asumed it would send the light ...but wanted to make sure...and like i said with the engine sitting on my front porch i couldnt check and verify
thanks alot for the reply
tony
tony
squarehead
01-15-2015 07:02 PM
