Rear Axle Bump Stop OPTIONS?
Re: Rear Axle Bump Stop OPTIONS?
I wouldn't delete them. The protect the shocks from over compression. They would also soften the impact of the body dropping onto the axle housing, possibly helping you maintain control in an extreme situation.
When my springs/shocks were worn out and the 10 year old bump stops went bad, it was totally horrible. The bump stops are only like 15 dollars a piecefrom gmpartsdirect.com and something like 25 a piece from a local dealer.
Every speedbump or pothole you could feel the axle slam into the body. You don't want to crack your whole unibody because you saved 50 bucks on bump stops.
The ones you get from gm now will be polyurethane too.
