Rear Brake Noise ?? Help
I have a brake noise in the rear of my 95 Z28. I have checked everything in the rear and I cant find anything. I have new rotors and pads and there is still a rough noise every time the wheel goes around only when I hit the brakes. It sounds like a rough grinding or rubbing noise.
It is only when I brake, !! I can hear it every time the wheel rotates, its not a constant grinding. !!
What can it be ?? !!
THANKS
THANKS
Check the H-clip( #17 )....It might be bent/damaged..
http://shbox.com/1/rear_caliper.jpg
Picture courtesy of Shoebox.......
trefidy
07-26-2002 03:40 PM
