rear brake problem
Re: rear brake problem
well, the front brakes are accountable for 60-70% or your braking, but it should still lockup easily. 1)make sure your pads are good and intact (assumnig u have disks) 2) if pads are good, check for piston possibly being stuck in the cylinder. corrosion or something over a period of sitting and weathering can possible cause it to stick permanently in worse case scenario.
Hey man, what came about from this? I am having the same problem! I have an ABS light on (ever since I installed my elec water pump over a year ago) and I just found out the rear brakes aren't working...could they be related? Emergency brake works fine though...just nothing in the rear when I apply the pedal.
F'n1996Z28SS
08-23-2023 11:19 PM
bossco
11-29-2014 10:18 AM
