Rear brakes to tight?
This is my first brake job on the z.Heres what I did:
-Took the cap off the brake master cylinder
-pulled the caliper off took the old brakes out
-installed the new rotors
-Installed the new brake pads with the backing plate and that little H clip that connects the two pads and installed them in the caliper after depressing it.
- Mounted the caliper back on and slid the pads over the rotor. It goes on but It is really tight. I was under the impression that the rotor should still turn freely and not contact the pads unless the brake pedal is pressed. It is a little hard to turn. Is that normal for it to be so tight?
carguy0119
04-11-2016 11:11 PM
