rear of car fishtails above 90mph
i have a couple ideas of what could be the problem but i wanted input from the board.
I bought my 93 wrecked and since then had the front end pulled over a inch.
the metal arm that goes from the rear end to the transmission is bent.it is almost touching the driveshaft. I have not yet replaced. the car has been driving fine under normal conditions<<<<<doing the speed limit. well on day i hit the highway and wanted to see how fast i could actually hit 150+ in the camaro....i had one scary ride coming. as i hit 90mph the car started to slightly fishtail. i backed off immeditaly. i went for it again and done the same thing. ...a few weeks past. I am now starting to notice my car shimmy doing normal driving. 30-50 mph stop and go traffic. this is starting to concern me and my parents. what do you'all think?
Re: rear of car fishtails above 90mph
Any suspension items that are bent need to be replaced. By your description, the metal arm is the torque arm. Pick one up at a junkyard or replace it with an aftermarket one if you have the money. Chances are, the transmission mount where the front of the torque arm attaches is also bent.
I also suggest you get a four wheel alignment after replacing the torque arm. That will tell you quite a bit about what's going on.
12-04-2014 11:56 AM
squarehead
11-21-2014 08:02 PM
