Rear drag springs needed for lowered 4th gen
My car has Qa1 8 way adjustables with eibach drag launch springs up front. In the rear, it has 6 way koni adjustable shocks with eibach lowering springs. I really like the stance and height of the car but think there is more to gain on the launch with a new set of drag springs. I don't want the car to have the rear end jacked up in the rear. Any ideas what I can use to get better wieght distribution and still keep the stance? The car has a 28" tall tire and the fenders are already rolled. Thanks.
Go to your local autoparts store, and buy 3ft. of 5/8" I.D. oil/fuel line hose.
Then, pull out the rear springs and the rubber upper spring seats; you will not be reusing the upper spring seats.
They'll be replaced by the Hose.
Now, slide the hose over the first full top coil of the rear spring. Finally cut the hose around 1/2" past the end of the coil spring. Re-install, and repeat on the other side with the remaining hose.
07-04-2005 05:00 PM
