Rear End CLUNK.... Could it be LCA's ???
#16
Here's another vote for not tight enough LCA's. After installing my SLP subframes, I started getting a "clunk" out of the rear at times. I initially thought the subframes were loose, but it still happened after tightening them down. I then wrote it off to LCA binding and had my mind set on upgrading them ... then while installing a tunnel brace, I decided to look up the torque specs of the LCA bolts in my service manual and they were no where close. After tightening them to the correct ft/lbs, no more clunking.
So, if you didn't tighten the LCA bolts with the car at curb height (ie: not on jack stands) using a torque wrench, go back and do this 1st.
Thomas.
Thomas.
#17
Thomas.
Thomas.
Also the rear end pretty much felt like its binding up and trying to lock itself in the turns... So tiny pieces are normal in the rear as well ?
I'm gonna put fluid back in it tommorow and hopefully it'll be better for a lil bit at least...
#21
It's ok to lift the rear as long as you support the rear axle so the suspension does not flex.
When I 1st read the service manual, I thought it said they had to be tightened with the car on the ground. But I read it again and realized it states that the suspension must be at curb height ... in other words, not flexed out at all.
Thomas.
Thomas.
#22
my car has 90k on it but it isnt the stock rear, I bought it used sometime last year..
I've yet to add more fluid and drive it again..
Hopefully tommorow if I get out of work early enough..
#24
Re: Rear End CLUNK.... Could it be LCA's ???
Originally Posted by GMH94Z28
Did you ever get this resolved? I am having a similar noise while turning and i just installed lca. Thanks
10-31-2016 11:09 AM
