rear end problem
rear end problem
i just bought a 96 camaro RS an guy had put on subframe connecters an panhard bar an i just installed lowering springs. cars still on jack stands since then i put on my 18s 245/45/18 an i noticed the pass. side tire is like an inch from the rocker an much bigger gap from back bumper an the driver side is about right 1 side of that wheel is lil closer then the one but all cars are like that. iam just wondering about the pass. side?
wow...i read that twice....and i still have NO IDEA what you were asking.
something about the location of the wheels/axle i think.
when you lower the car, the geometry of the rear suspension is thrown off. the axle will be shifted to one side. an adjustable panhard bar solves this issue.
issues front to back would be a frame problem or LCA issue
In other words, the passenger side tire looks like it is located too far forward in the wheel opening? Why not drop it to the ground and take some actual measurements?
thats wat iam saying not dropign it yet since its on all 4 jacks since iam wating for the rest of the exhaust to come.so i can install it them after that then it will be on the ground dnt wanna undo it all then redo it again.
10-31-2016 11:09 AM
