rear suspension noise
I had the same thing,turned out to be the LCA bushings,spraying them didn't help mine,rather then just replace them bushings which can be a lot of work I replaced the LCA's with units that had poly bushings with gease fittings,that took care of the problem
There are grease points on the calipers.. Did you grease ????? Alot of people forget about this and it could cause the pad to stick...
F'n1996Z28SS
08-23-2023 11:19 PM
94z28jbw
09-08-2002 03:22 PM
guionM
18
07-23-2002 04:24 AM
