rear suspension squeels like a dying pig
First i thought i was all the poly bushings .. had them all greased .. it still squeels really bad
can shocks squeel like that ? I got Koni DAs, could it be the springs sitting in their perch ?
every time i hit a little bump they squeek and squeel .. not sure if its a convertible curse, or if its something to do with my suspension
![Cry](https://www.camaroz28.com/forums/images/smilies/cry.gif)
Originally posted by sideways_Into_3rd
sounds like it could be coming from both sides .. how do i fix it ?
You could put rod end for everything
![Wink](https://www.camaroz28.com/forums/images/smilies/wink.gif)
I think its the springs though, how do you fix this.... I'm not sure, I have seen people putting a peice of garden hose over the bottom of it.
yeah I've been thinking about doing that to raise the back end a touch .. but not sure how thats gonna help the squeels
edit: oh you said the bottom
thats a good idea
maybe since i got a moser rear end, the bottom perch isnt perfect and the spring moves around or something
![ALERT](https://www.camaroz28.com/forums/images/smilies/alert.gif)
![Thinking](https://www.camaroz28.com/forums/images/smilies/think.gif)
get a short piece of garden hose and use it as a stethascope while someone is pushing down on the back end, to find where the squeek is coming from. I recently did this and found that it was my rear sway bar's main bushing causing a squeek. I just dropped the sway bar, greased up the bushing, and bolted it back into place .... no more squeek ![Smilie](https://www.camaroz28.com/forums/images/smilies/smile.gif)
Thomas.
Thomas.
F'n1996Z28SS
08-23-2023 11:19 PM
grabbem88
03-18-2015 01:25 PM
94z28jbw
09-08-2002 03:22 PM
guionM
18
07-23-2002 04:24 AM
