rear sway bar, not lining up
I installed a new moser 12 bolt and bmr control arms, now i am having troubles mounting up the new sway bar. i don't think the hellwig corp. would think someone would be installing there product on a 12 bolt but it is not lining up right. anyone with any advice or info would greatly be apprecieated.
Jessie
Jessie
Re: rear sway bar, not lining up
If you're having the trouble that I think you are using the stock u-bolts and brackets they won't work. I ended up buying a set of brackets made for the Moser axle size, 3", and then had them welded up. The stock sway can then just be bolted up without using the u-bolt at all.
Check out Spohn Performance. They make specific sway bar mounts for 12 bolts/9" rears. It properly locates the sway bar and should make mounting it very easy...They go for $75.....www.spohn.net
--Alan
--Alan
--Alan
--Alan
F'n1996Z28SS
08-23-2023 11:19 PM
