Rear wheel speed sensors 98+ backing plates rear
HEllo,
I would like to know where do you fit the wheel speed sensors and/or if you have a picture of the 98+ backing plates
I wanted a special rear through tbyrne from strange and it looks like they installed the incorrect backing plates onto my new Strange 12bolt...
The reluctor rings are installed on the axles but the backing plates have no provisions for wheel speed sensor..
any pictures of the backing plates is appreciated...
Re: Rear wheel speed sensors 98+ backing plates rear
speed sensor is embedded in the axle. and if you got the wrong plates you'll have to take the axle to a nearby dealer to see what they can do for you.
Highlander
If you have ASR the speed sensors go in the backing . There should be a circular hole about 1 inch in diameter to mount each speed sensor in the backing plates. If it is not there you should be able to use yuor backing plates . You may have to pressoff a bearing and pressit back on , if the axles came assembled.
can the backing plates be removed? i think they are soldered.
Originally Posted by The Highlander
. i guess i have to drill a hole and then put the sensor in there...
squarehead
11-21-2014 08:02 PM
07-04-2005 05:00 PM
regular Joe
08-10-2002 07:15 PM
