Removing springs without a spring compressor?
I've removed the springs on two of my third gens with out spring compressors, just with a floor jack, and I had no issues. I'm going to be doing suspension on my 4th gen soon and I was wondering if I needed a spring compressor for it, I know the front the suspension is different, and I really don't want to kill myself, I want to be able to drive the car afterwards.
Thanks for the help.
Re: Removing springs without a spring compressor?
You can remove the spring/shock assemblies and take them down to a shop to have the parts swapped; around $40 - $50. You can also buy a set of spring compressors (threaded style) and do the complete swap in your garage. I've done it both ways; the trick with the threaded style compressors is to keep the threads well lubricated with thick grease.
I installed Sportlines on the front of my '98 in my garage. I went to Autozone and rented a spring compressor kit. It was like $40, but there was no time limit and when I took it back, I got my $$ back. Just keep your receipt.
I used a Lisle PN 62300 McPherson Strut Tool. The instructions specifically mention it is NOT for spring removal, but I like the design. The clips actually u-bolt to the spring coils, so they can’t pop off, and can’t start to slip around the spring coils. Doesn't cost much more than a rental, and I've done a few more seperations for friends, and loaned it out a couple times.
I have a painfully detailed "how to" on the spring/shock swap for the 4th Gens:
http://members.aol.com/InjuneerZZ/HALEibch.htm
10-31-2016 11:09 AM
GA93FORMULA
07-24-2002 11:38 PM
