Replacing rear spring isolators with hose
I know this mod has been around for a long time to drop the rear height. Wondering if anyone has suffered damage to the body as the isolator distributes the load; in other words can the spring covered with hose dig into the sheet metal over time? Thanks.
OBE1 95Z28
Use heater hose that's a tight fit and the inside the hose lube is needed to slide the hose on the spring coil. I think I used a little on top to protect against the hose from abrading and possibly wearing though.
Sleepy_Z:
I've been trying to keep any stock pieces I remove from the car as is. I suppose you might be able to use a surface grinder to "shave" the stock isolator evenly but I think it would be quicker and easier to slide hose over the last coil of the spring and try them out to find out if you like it. Easy to go back if it doesn't work.
The isolator isn't very tall so cutting would most likely cause it to fail; probably will only drop the height 1/2" max. I'm running Spohn's lowering springs but my 9" Moser differential has larger axle tubes than the stock axle causing the rear wheel gap to be taller than the front wheel gap.
10-31-2016 11:09 AM
