ride height problem
Old 01-09-2007, 07:15 AM
  #31
SpeedDemon02SS's Avatar
still stock controll arms. and rubber bushings. i am going to wait until i do the k-member to change all of that stuff.
anyway, i thank you. i will give this a try. ill repost in a few days after i get it all apart.
SpeedDemon02SS is offline
Old 01-10-2007, 10:08 PM
  #32
ChrisRZ28's Avatar
[QUOTE=blackrat;4327843]Seems to be a typical problem with eibach springs
My 2001 Z28 sat 3/4" higher on the drivers side with STOCK springs.
ChrisRZ28 is offline
Old 01-10-2007, 10:15 PM
  #33
mine sat funny with the stockers too. thats why i know its not the eibachs.
Old 01-10-2007, 11:35 PM
  #34
scof0elife's Avatar
Its just a side effect our Fbodies get
scof0elife is offline
Old 01-11-2007, 06:30 AM
  #35
**** me off. i dont want a side effect.
Old 01-12-2007, 08:28 PM
  #36
blackrat's Avatar
if anyone notices just tell them it's because of all the torque.
blackrat is offline
Old 01-12-2007, 10:02 PM
  #37
i was thinking of telling people "Its that way because your mom sat in it"
Old 01-14-2007, 11:35 PM
  #38
94/96ZsM6s's Avatar
i had the same issue on the left front after a complete suspension overhaul...left frt upper strut mount were the culprit.....but my 94 had a hard 95k on it. replaced them and ride height is level again. in your case this might not be the issue because i'm asuming your 2002 dosen't have almost 100k on it. just my .02
94/96ZsM6s is offline
Old 01-15-2007, 07:04 AM
  #39
no, 40k. but im gonna check evertyhing again when i re-aligh the controll arms. but are you talking about the rubber part taht sits at the top of the spring?
Old 01-15-2007, 01:11 PM
  #40
94/96ZsM6s's Avatar
yes the rubber mount at that holds the spring/shock (strut) together at the top. if you can take the strut out, (driver side is more complicated because of master cylinder) look in the area were the shock proturdes through the rubber mont with the nut holding the shock and rubber mount inplace. if it torn or in bad shape that is most likely the culprit. with only 40k on the car, it sems unlikely the strut mount is the problem.
Old 01-15-2007, 01:13 PM
  #41
yea, those were all good. i am happy its the passanger side, cause they drivers side takes an extra hour each time i take it out. i am going ot try to re-alighn the controll arms, and if not, im gonna fab a spacer to fit between the spring seat and the shock brace.
canbaufo
05-17-2015 10:35 AM
StreetDriven
03-15-2015 07:12 PM
cmdeshon
12-12-2014 10:51 PM
jeff94z28
09-11-2002 02:01 PM
MBonZ28
07-30-2002 11:42 AM
Quick Reply: ride height problem
