Rmoving the LCA's?
Rmoving the LCA's?
I will be pulling mine off this week and was wondering if anyone had any heads-ups for me. I believe the bolt is an 18mm or so but I can't seem to get a good setting on the head. Everything is perfectly placed in the way. Any suggestions will be much apprecited. Thanks!
Re: Rmoving the LCA's?
I used a 3/4 socket on the nut and an universal wrench to keep the bolt from moving. I think the 3/4 was a little big (although it worked fine) so 18mm should work.
The LCAs shouldn't be bad at all. The problem is that the bolt/nut may be rusted and it will be hard to take it out so you might want to spray some wd40 on it the night before.
I recommend using PB Blaster. Even then I had to stand on the breaker bar to get the damn things loose. Remember, one side at a time. If the new ones don't fit, jack up/lower the rear until it lines back up.
![Thumbs up!](https://www.camaroz28.com/forums/images/smilies/thumb.gif)
carguyshu
01-22-2017 11:19 AM
96SilverRam
11-20-2016 11:19 AM
Henson071
12-30-2015 09:55 PM
