Rotors from ebay
Re: Rotors from ebay
haha i bought some rotors drilled/slotted off e-bay , 169 fro all 4 , never gave me a problem , got them in a few days, def better than stock but lt1 brakes still suck ,
check out my homepage to c them , all and all they were not bad and even after alot of hard braking they still have not cracked or anything,
only downsideis the squeak like a bitch but its not the rotors i have to use some antisqeak crap for teh pads
I would also recommend a non slotted non drilled rotor.
If you want the bling, go for the cross drilled/slotted look. If you aren't crazy with your brakes, they will be fine most likely.
I like the idea of a slotted rotor (just for looks mainly), but they are hard to find at a decent price ($60 or less each).
Dan
Dan
i have the same ones as CamaroSS30thAnn, look on my cardomain for the detailed pics, they are reall nice, they cracked a little around the drilled ports, but nothing too serious. and they do squeek a little, but thats due to the carbon metalic pads i have...
Dan
Dan
karpetcm
09-29-2015 10:08 AM
