SFC + LCA relocation brackets
I've got a 94 Z28 vert with BMR subframe connectors and I'd like to get a set of LCA relocation brackets installed. However, I know my weld-in SFC connects to the rear LCA bolts. Does this pose a problem with the bolt locations if I'm gonna get new LCA brackets installed? I'd assume "no", but I thought I'd make sure.
Re: SFC + LCA relocation brackets
The brackets that you are talking about goes onto the other side of the control arms which is on the axle and should be fine and probably would be best to weld it.
Nayr
03-03-2023 08:34 PM
