SFCs installed/ 80mph+ major vibration
just had some tubular weld in SFCs installed and now at higher speeds 80mph+ there is a lot more vibration throughout the whole car. i can watch the passenger side seat shake from the vibration ...is this normal or should i do something to adjust this? any info would be great!!
It's possible that the SFCs are allowing more vibration inside the car. You might want to check balance/condition of your tires & rims or see if anything else might be causing it. As an example, before I got new tires and SFCs the seat would shake. New tires took care of the problem, and the BMR boxed SFCs don't cause any extra vibration at all (firmer, but I actually like how that feels compared to chassis/body flex).
autoxr166
09-25-2015 04:21 PM
