Shock/Spring Question
Can you buy shocks with the springs already installed on them as a unit for 4th gens? Like a ready to bolt on type of package? Looking into getting some bilstein hd's this year but don't see them sold that way. Also wondering about the possibility of just reusing the springs I have...but they're 15 years old, as are the shocks. Any way to tell if they're shot? I want to do this myself...nobody's turned a wrench on this car but me since I've had it, and I'd rather do it myself, I'm just not sure about putting the shocks/springs together...
Re: Shock/Spring Question
It's not that hard to break down the stockers and reassemble the new parts. You should get new upper seats, since they rot and the shock mount portion can tear loose from the rest of the seat. The top nut on the shock shaft will be rusted solid, and you will probably have to cut the shock shaft to take things apart.
Takes a simple strut compressor (even though they aren't struts).
I have an online guide. Just ignore the stuff that's peculiar to the QA1 shocks.
http://www.injuneer.com/HALEibch.html
http://www.injuneer.com/images/photos/shk02.jpg
http://www.injuneer.com/images/photos/shk01.jpg
Thanks for the info guys..I'm probably going to reuse my stock springs and get bilsteins...is this dumb? Meaning, is that a waste of a good shock, and would I be better off with a cheaper shock? Reason for going with this is I have a somewhat steep driveway with a lip at the top..I don't want to lower it with eibach or similar springs, it would suck if I started scraping and had to raise it again. What is driving this whole thing is that my stock shocks are shot and need to be replaced but I have no idea how to tell if the stock springs are "reusable". The price for new "stock height" springs plus the bilsteins is throwing my upgrade budget through the roof...I need new brakes and wheels/tires too... And as for the bilsteins..I see there are "SLP" bilsteins and bilstein hd's...with the hd's seeming to be a bit more in cost. Is there a difference? Can either of these shocks be used with stock height springs?
Figured I'd post a follow-up in case someone else was wondering the same thing I was and searched for it. Emailed Sam Strano and he said there's no difference between the Bilstein HD's and SLP's except for price...so I'll obviously be getting the cheaper one's (SLP). Not lowering the car because I just don't want to deal with everything else that goes with it right now so we'll just do shocks. Still on the fence as to whether I should replace the stock springs with new stock springs...I probably won't, it doesn't seem to be sagging or anything. So shocks and top mounts.
z0s0, let me know your thoughts on the Bilstein setup when you get it on the road. I'm fine with my current ride height, but I would like to eventually replace the DeCarbons with a better damper. I don't have a Koni budget, and I'm not too keen on buying the cheaper adjustable shocks, so I've considered going the Bilstein route. I'm curious to see how they perform with the stock springs since I daily drive my car and the roads around here are not kind to lowered cars. For instance, I recently witnessed a lowered Civic having its front bumper/body kit removed by an angry Cleveland pothole.
The slp beilstein shocks are valved for the spring/ shock combo on certain ls1 model f-body's which was a 1in drop iirc.But I talked to sam strain a couple days ago and he said that the regular hd's and slp's are the same now?
dluna333
15
03-13-2015 12:30 PM
jasonduaine
03-07-2015 09:44 AM
Hurin
12-13-2014 07:38 PM
