Shock/Spring set-up reccomendations
To start off, I did try searching but there doesn't seem to be anytihng that relates directly to my position. I will try to describe my situation as best as I can.
I have a '96 Camaro SS with the basic suspension upgrades from SLP, which I believe is the larger sway bar. Recently I have added a Hotchkis STB and BMR subframe connectors.
I am more of a drag racer then autocross. In fact, I do not see myself autocrossing at all due to having an automatic. Handling is not much of a concern with me as looks are. I am wanting to lower my car about an inch or a little more and retain about the stock ride quality. One thing that I must say about the subframe connectors is that I feel the road a lot better, which I love. I don't really mind a harsher ride as evident with the SFC's. I will also be in the near future installing Pacesetter longtubes and 17x11 ZR1's with the 50mm offset in the rear.
I do not have a lot of money to spend here. I am looking at buying the Bilstein HD's and this lowering kit from Thunder Racing and combining it with the HD's. What do you guys think would be the best? I have also noticed SLP's kit with the SLP Eibachs and Bilsteins. Some reccomend that kit but it is somewhat pricy at like $600.
94DROPTOPZ28
N2O Tech
10
01-10-2003 01:41 AM
FilledWithFurySS
12-04-2002 10:38 AM
teke184
10-28-2002 01:20 PM
DarthIROC
3rd Gen / L98 Engine Tech
09-05-2002 11:56 PM
jim88iroc305
08-13-2002 09:24 PM
