Shocks and bars !?!?!?!
I have spent all morning searching and reading posts on suspension mods. I am by no means an expert, just wanted to do some educating before posting. I would like to set up my 95Z with a suspension that is more traction oriented than ride comfort. I have read alot of Sam Strano's replies and have come up with a few questions. I believe the front bar needs to be 35mm. What do I put in the rear? Do I keep the stock 19mm or go up to 21 or 25? The other mod will be shocks. I can't afford the Koni adjustables ($800 I think). I plan on keeping the stock springs. Do I go with the Bilstein HD or revalve? I don't want to lower the car (not sure exhaust will clear speed bumps, already bottom with full fuel and passenger). Car already has SFC's, LCA's and PHR. Torque arm is in the works. I am running the stock tire/wheel 16X8. Any input would be great. I don't want to spent the same money twice on these mods, I'd rather put it in the fuel tank. thanks in advance.
Re: Shocks and bars !?!?!?!
Depends....
I would get the soild 35mm or maybe the hollow depeonds on what your doing either blistens would work.
But I personally would keep the back bar 19mm.
CALL SAM
CALL SAM
Bigfatrat
Parts Wanted
10-16-2015 04:48 PM
08-05-2015 08:35 AM
