shocks suggestions.
shocks suggestions.
posted for tires in the tire section, now I need shocks, my car is my Daily driver, basically stock. What are some shock suggestions?? I dont want the stock ones, since Im replacing them, I'd like to upgrade. Any suggestions?
Is your car lowered, or do you plan on lowering it? If not, you can go with regular Bilstein HD's. If you are going to lower it, get Sam Strano's revalved Bilsteins. Sam is a sponser here www.stranoparts.com
HD's are $349 for the set of 4.... I do use a different rear shock than the current HD part number though. Bilstein went and F'ed up a good thing and changed the rears, so I use an older valving that works better. I'm the only one who does that, and probably the only one who can tell you why.
![Smilie](https://www.camaroz28.com/forums/images/smilies/smile.gif)
karpetcm
12-16-2015 09:07 PM
Bigfatrat
Parts Wanted
10-16-2015 04:48 PM
