shortening rod ends after lowering
So I've read that after lowering, the "correct" way to do it is to shorten the endlinks on the sway bar, I assume that getting a shorter bolt and a sleeve that is shorter the same amount that I'm dropped will do it.
Curious as to what those longer endlinks do, how does the longer bolts/sleeves affect handling? Does it give the bar more leverlage? Does it preload it and not let it do it's job as well? Just curious
10-31-2016 11:09 AM
oldschool
02-09-2016 09:21 PM
HectorM52
01-31-2015 07:29 PM
Hurin
12-13-2014 07:38 PM
