SJM ABS delete/line lock kit and tcs removal
Ok i want to cancel and take off my abs stuff(module,wire etc.) and also my tcs stuff(wire,module etc.)
Im going to buy the complete kit from SJM(proportion valve,line lock,prebent lines and flairing tool,etc.)
-I ve found this about the removal of abs:
http://www.pharmacy.arizona.edu/staf...veABSunit.html
-I found this on the tcs removal:
http://www.pharmacy.arizona.edu/staf...veTCSunit.html
-And the install of a proportion valve:
http://www.pharmacy.arizona.edu/staf...PropValve.html
Now that i know how to remove everything does anyone know precisly how to reconnect all the brake lines so that everything work or have any link(with pics).
Also i have found the kit but they ask me if i got 3 channel or 4 channel, since im deleting the tcs module, do i order 3 channel or 4 channel?
Thank you
Thank you
Re: SJM ABS delete/line lock kit and tcs removal
if you have tcs you need a 4 channel.it comes with everything you need,including new lines .i did it on my 97ss and it only took a couple hours.it's a 3 channel and was pretty simple to do.
jj_burchiel
03-21-2015 12:51 AM
squarehead
01-15-2015 07:02 PM
GA93FORMULA
07-24-2002 11:38 PM
