SJM ABS delete pictures
The SJM kit is pretty straight forward. I used all their lines to run from the master cylinder to the line loc and proportioning valve. I chose to connect the proportioning valve to my rear brake line a little different than they call fo, as well as the way I connected the line loc to the front brake lines. I bent all new brake lines to follow the tubes on my AJE k-member.
Looking good! You need a couple of black plugs to fill in the few holes though. That's one off the mods I'd like to do in the future. But I'm thinking as I save up for some more go fast parts, one of your 4l60e's will probably happen first.
carguyshu
01-22-2017 11:19 AM
alex5366
03-08-2015 11:32 AM
squarehead
01-15-2015 07:02 PM
