Spohn adjustable torque arm install??(PLEASE)
I receive mine today but it came without install instruction.I know the basic to put it on the car, thats not a problem.
But there s 2 big bolts on the pieces that connect on the cross member.One of them pass trought the polyurethane bushing and the other one keeps the pieces together.Do i have to tight these bolts very hard or should i left a small play??
And how do i adjust it with the angle finder???
And is there anything that i should know?
Re: Spohn adjustable torque arm install??(PLEASE)
Tighten the rearend bolts and tighten the mount. Leave everyting else loose. After you set the pinion angle, then tighten the side bolts. I used an impact gun on the rear and some wrenches on the sides.
