spohn panhard bar
spohn panhard bar
does a non adjustable panhard bar from spohn improve centering the rearend or would it be a waste to get a non adjustable. my rear is not centered and i can get this panhard off of a wrecked car right now pretty cheap but its a non adjust tubular. this car also has non adjustable spohn trackbars. would those benefit much?
Re: spohn panhard bar
thats what im thinking even though all the sites say that the non adjust re centers the axle and the adjustable is for lowered cars. i mean it might be worth it to see if it changes at all and it should handle a lil better
If the new bar is longer or shorter than OEM, than yes, it can move the left wheel in or out from the centerline. However, since aftermarket non-adjustable bars are supossed to be the same legth as the OEM bar, it will not move the axle fore or aft. Take a look at how the bar mounts. One side attaches to the body of the car, the other the axle. A longer bar will push the axle to the left, a shorter will pull the axle to the right.
sleeperZ96BT
09-09-2015 08:28 AM
