Spohn Problems....
Spohn Problems....
For those that have the SPohn TQ arm... and Diamond Subframe connectors... where in the h3ll did you find the longer bolts needed to bolt the thing in under the chassy? I can't find this d@mn bolt anywhere... it's getting annoying... is there a place online that sells the 8 grade metric bolt...
![Dead](https://www.camaroz28.com/forums/images/smilies/dead.gif)
Re: Spohn Problems....
you should be able to pick them up at any hardware store..If you get the instructions that were provided with the torque arm, it tells you the specs of the bolt needed. Good luck.
1. Suspension problems belong on the "Suspension...." forum, not on LT1 Engine Tech.
2. I don't see this as a "Spohn" problem... he can't be expected to anticipate every possible combination of installs. All you need to do is buy new bolts. Try McMaster-Carr if you can't find them at your local hardware store.
Originally Posted by Heatmaker
Woa... easy thurr.... I wasn't bad mouthing or complaining about spohn... this torque arm is awsome and worth every penny... Quality up and down...
![Smilie](https://www.camaroz28.com/forums/images/smilies/smile.gif)
I"m just asking where I can find the longer bolts for it... like if anyone knew of a place online or something.. because I"ve been every where with the bolt specs in hand...and no one carries the bolt. I've stopped down every store from Napa to Homdepot...with no look... even hitting up local hardwares... just need some direction.
You're the one who typed "Spohn Problems...." for the topic. In fact, the problem is "I can't find bolts...." ![Smilie](https://www.camaroz28.com/forums/images/smilies/smile.gif)
And I told you to try McMaster-Carr.... that is a "place online."
+1 for the Spohn stuff, I have LOTS of Spohn parts on my car
![Bow](https://www.camaroz28.com/forums/images/smilies/bow.gif)
Henson071
12-30-2015 09:55 PM
96SilverRam
05-28-2015 02:09 AM
