Spohn Torque Arm
Spohn Torque Arm
Anyone useing this torque arm? http://www.spohn.net/shop/1993-1997-...n-Mounted.html I am curious if it is as quiet as they say. It uses solid rod ends instead of spherical rod ends to reduce noise. I currently have a tunnel mounted TA and the road noise drives me crazy. The car is 100% street car.
You don't need spherical rod ends in the rear mount, so I doubt any manufacturer would use them. All Spohn's TA's have solid rod ends in the rear mount.
I can't see any reason that TA would make any more noise than the stock arm, other than the use of the poly front bushing in place of the stock soft rubber bushing. I ran a poly bushing with the stock arm and never noticed any noise.
autoxr166
09-25-2015 04:21 PM
