springs???
springs???
hey wassup guys well my buddy has a 00 or 01 cant remember, camaro ss with the 1LE package, will the springs on his camaro ss fit on my 94 z28???? has any one done this before please let me know how it rides he also gave me the LCA and his sway bars ....thanks
Re: springs???
The springs will fit but your 94 will sit lower in the front because the LT1 is heavier than the LS1.
His LCAs are the same as yours.
The sway bars are a bit larger and would be nice to have.
Re'
Re'
Re: springs???
I have a set of 1LE front springs from an LT1 car that im lookin to get rid of if your interested. Would keep the car sitting evenly all around.
Hit me up with a PM if you want em, im not looking to get a lot for them
Re: springs???
No. Lt1 and LS1 rears are VERY similar in spring rate. However, if you want a bit lower up front and a bit lower in the rear, the LS1 1LEs in the front, combined with removing the upper rubber spacer ring in the rear, will give you about 1" lower front and 3/4" lower rear. NOTE: If you DO remove the upper spring spacer, you MUST slide some heater hose over the upper coil. Don't cut the hose; pick some that with a good bit of silicone lube can be forced onto the coil itself. Use a good foot and a half, sliding it around a full coil or two.
Louey
Pacific
07-21-2015 10:06 PM
Catmaigne
07-14-2015 05:17 PM
