Squeaking on every turn
My car is squeaking on every turn i make. I don't think it is brake related because it does it when the break isnt pushed although i know they are able to drag somewhat. I would like to get it fixed but i dont know how to pinpoint what is squeaking and not spend extra money to fix other things. I will regrease my tie rods as that is pretty much the only thing i can think of. It seems to be coming from the front.
I do have umi lcas and phb but i believe they are lubed good and shouldnt be making this type of noise. Does anyone have any ideas?
Re: Squeaking on every turn
I also have a very loud squeak with mine, but only when I make hard left turns. I've looked at the breaks on all four corners and can't find anything abnormal that would cause the noise. I hope you have better luck.
a friend of mine bought a used transam and found whatever knucklehead owned it before him ziptied the parking brake cable out of the way of somthing and that caused a tiny bit of tension to be applied to the rear drivers brake but only enough to ellicet a squeek on a turn. Check that the cable is unobstructed and unimpaired.
jasonduaine
03-07-2015 09:44 AM
formula79
26
08-05-2002 12:21 PM
