Squeaking When Turning Left Only???
![Question](https://www.camaroz28.com/forums/images/icons/icon5.gif)
Alright here it goes...
When i make a left turn, and only a left turn, between 15 -25mphs there is
a squeak from when the back begins to make the turn until the back is straight once the turn is complete. Its not the breaks as i thought it was
since i dont hit the breaks when turning left at a light if there are no cars coming. The squeak sounds like when your brakes just begin to go out and its a high pitched squeak and not a grind. I cant figure out if its coming from the front or the back. The front end is pretty sloppy because it feels really loose and in small 15mphs speed bumps going at 10mph i hear clunking in
the front....anyone have any suggestions on what might be causing this squeak>??????
Re: Squeaking When Turning Left Only???
formula79
26
08-05-2002 12:21 PM
